How can I remove a stripped screw from the logic board?
One of the 3.1mm screw heads is ruined and I can’t get the screw out. Any suggestions on how to get that out?
Questa è una buona domanda?
Hey…if you can get access, a good sharp pair of wire cutters with sharp points will grip the ruined centre and the side of the screw…but you got to squeeze.
use a 2mm drill carefully to remove most of the screw head, then use a 4mm drill to clean up. then pull the plastic case over wjha’s left of the screw. you can get the rest of the screw out with cutter or fine pliers.
Ultime 24 Ore: 0
Ultimi 7 Giorni: 2
Ultimi 30 Giorni: 3
Tutti i Tempi: 66
