Salta al contenuto principale
Model A1347. Released on July 21, 2011. Core i5 or Core i7 Processor. Thunderbolt. This unit is also used to run the Mac mini Server configuration.
How can I upgrade the operating system to Catalina
How can I update the ram and SSD and what ones do I need and how do I updated to Catalina
Questa è una buona domanda?
Punteggio 0
Aggiungi un commento
1 Risposta
Technically this system only supports upto macOS High Sierra (10.13.6)
While there are a few hacks which you could use I really don’t recommend them if you are dependent on this system for school or work. You also won’t get many of the major features as there is dependency within the hardware. I recommend you stick the either Sierra or High Sierra.
Here’s the guide to upgrade your RAM - Sostituzione RAM Mac mini versione metà 2011
To add a SSD I would add it as a second drive following this guide - Installazione dell'SSD Dual Drive nel Mac Mini, versione metà 2011
Immagine Mac mini Mid 2011 RAM
Guida
Difficoltà:
Molto facile
5 - 10 minutes
Immagine Mac mini Mid 2011 Kit per doppio Hard Drive
Guida
Difficoltà:
Moderato
2 - 4 hours
Punteggio 0
Aggiungi la tua risposta
Don sarà eternamente grato.
Visualizza Statistiche:
Ultime 24 Ore: 0
Ultimi 7 Giorni: 0
Ultimi 30 Giorni: 3
Tutti i Tempi: 129
