Salta al contenuto principale
In seguito alla forma più sottile e più piccola del Lenovo Yoga due in uno, il Lenovo IdeaPad Flex 5-1570 ti offre un'ottima performance, usando un processore Intel Core i5-8250U da 1.6GHz e un adattatore video integrato Intel UHD Graphics 620.
10 Domande Visualizza tutte
Replacement battery has same part number but doesn’t match.
Ordered a replacement battery, both the replacement and the original equipment have the same part number L15M3PB0. However the tabs and the wire colors do not match perfectly to the original. Some of the tabs are the same which I can adapt with. But the wire colors are not the same which causes me to hold off. Can anyone verify that event the colors of the wires are slightly different they are in fact the same order of use?
Update (12/09/2020)
This is not going to work as I thought. The mounting locations in the package looked like it would fit, but as I attempted to install they are not close enough.
Questa è una buona domanda?
Punteggio 0
Aggiungi un commento
2 Risposte
Risposta Più Utile
Daniel Clark we could only verify this if we can get our hands on the actual battery. Luckily the wire colors of batteries are no standardize thus different manufacturers often use their own wiring colors. For as long as the battery and all the functions remain, it will no matter. The only thing I would make sure is that the wires coming from the positive and negative poles from the battery will go the proper points on your motherboard connector. Let us know how it works out.
Punteggio 1
Hi,
Whilst it may have the same battery type (or series? perhaps) number i.e. L15M3PB0, the replacement battery hasn’t got the same Lenovo battery part number.
Assuming the original battery is the one shown connected to the motherboard in the 1st image, then on the barcode label it has the part number beginning with 8S5B10M49824——— ——.
The 5B10M49824 corresponds with the part number for one of the batteries (item #13 Lenovo ideapad FLEX 5- 1570 column) shown on p.72 in the hardware maintenance manual for the laptop and also what is shown for one of the 3 compatible batteries in the parts list as well (click on Select Commodity > Rechargeable batteries and Internal (3).
Your replacement battery part number is 8S5B10K84494 ———, and it is not listed for this laptop model. Searching online using this part number (omit the 8S from the beginning and search using 5B10K84494) shows what models it may be used on. (I say may because perhaps it may not be. The seller may be relying on the type number as you did and for other batteries at least is usually correct. The parts list for the mentioned device may need to be checked to verify. )
I don’t know why both the batteries have the same type (or series) number, as you would think then that they would be identical. Also if they were the same then why not have the same part number as well??
Given the above, it may be prudent to search using the specific Lenovo part number when looking for Lenovo parts.
Punteggio 1
Aggiungi la tua risposta
Daniel Clark sarà eternamente grato.
Visualizza Statistiche:
Ultime 24 Ore: 0
Ultimi 7 Giorni: 13
Ultimi 30 Giorni: 19
Tutti i Tempi: 313
