Salta al contenuto principale
Apple's 6th revision to the iPod Touch lineup, released in July 2015.
My screen will not work no matter what.
My screen will not work no matter what. Before you ask, yes, I’ve tried doing a hard reset. When I plug it in, it makes the charging noise. Is there anything I can do?
Questa è una buona domanda?
Punteggio 0
Aggiungi un commento
1 Risposta
Risposta Più Utile
yerbamate since you already tried everything you can via reset etc. (it does get recognized in iTunes the issue maybe your screen. Consider replacing it and while you are doing so you may need to check the logic board components, connectors and cables. Download 3uTools and see what it tells you about your device.
Punteggio 1
Aggiungi la tua risposta
yerbamate sarà eternamente grato.
Visualizza Statistiche:
Ultime 24 Ore: 0
Ultimi 7 Giorni: 0
Ultimi 30 Giorni: 0
Tutti i Tempi: 47
