Salta al contenuto principale
La quinta generazione debuttò a gennaio 2005.
28 Domande Visualizza tutte
Why does my engine not turn over?
It wasn't going into gear. You push in shifter button and nothing. So we pulled the shifter casing and saw that an pin wasn't engaging and wouldn't let it go into gear. So we manipulated it by pushing the little pin in to unlock shifter and be able to out in gear. The little motor or solenoid  is 400.00. So they went to pull n pay and took whole thing. Shifter casing solenoid.  Installed it. Drove it. It ran cherry. Went home turned it off and it wouldn't start again.
Questa è una buona domanda?
Punteggio 0
Aggiungi un commento
1 Risposta
Not sure what was replaced? Could you try to make that clearer? Did the starter itself get replaced?
Punteggio 0
Aggiungi la tua risposta
Marlene sarà eternamente grato.
Visualizza Statistiche:
Ultime 24 Ore: 0
Ultimi 7 Giorni: 1
Ultimi 30 Giorni: 2
Tutti i Tempi: 53
