Salta al contenuto principale
Model A1181: 1.83, 2, 2.1, 2.13, 2.16, 2.2, or 2.4 GHz Core 2 Duo processor
1203 Domande Visualizza tutte
Domanda Chiusa
Where is the cmos battery?
I have a liquid damaged 2007 macbook 2.1 GHZ (A1181) that's working fine but isn't charging the battery.
I swapped out the DC in board and battery connector with known working parts but the issue remains.
I tried an SMC reset several times but to no avail.
I decided to disassemble it to clean up the logic board (there was some corrosion on some areas) but when I took it out and turned it round to remove the cmos battery there wasn't one. I assumed it was removed and not replaced as the macbook had clearly been opened before, but I couldn't find the jack for it.
Here's the type of logic board: http://www.techex.biz/ebaybiz/pics/Mothe...
This is the one I've seen before, where the cmos battery is placed in the middle of the board:
http://67.19.154.220/HQ/apple_macbook_a1...
Where is the cmos battery to be connected on this logic board?
Questa è una buona domanda?
Punteggio 0
Aggiungi un commento
1 Risposta
Soluzione Prescelta
It sounds like you have the Santa Rosa or Penryn version of the MacBook which has a slightly different location than earlier models. Here is the guide showing the location.
Punteggio 1
1 Commento:
Thanks Matt! Not calling it the "PRAM Battery" was obviously the downfall of my fruitless searching.
da
Visualizza Statistiche:
Ultime 24 Ore: 0
Ultimi 7 Giorni: 1
Ultimi 30 Giorni: 2
Tutti i Tempi: 10,902
