Face ID and phone restarting
My 11 pro Max phone is restarting every 3 mints water it got damage by liquid and Face ID is not working except tht 2 everything is working good
Questa è una buona domanda?
The first thing to try would be a battery replacement followed by the dock connector. These are the main two reasons the phone would restart every few minutes.
I have had a iPhone 7 Plus in the past that had water damage and a similar problem of frequently shutting off and the home button not working. I would recommend fully shutting down the iPhone, removing the SIM card tray, and leaving it in an open air environment to dry out for about a week or two. This usually dries out the components and I was able to get the iPhone to stop restarting and get the home button working again. You could try to blow dry the phone on a low heat setting, but this should be a last resort. Rice and silica packs do not work very well for liquid damage.
Ultime 24 Ore: 2
Ultimi 7 Giorni: 10
Ultimi 30 Giorni: 30
Tutti i Tempi: 515
1 Commento
Did you eventually fix your problem??
da Roman Alifanov
