Salta al contenuto principale
Questa guida è per il Lenovo Yoga 720-15IKB. Lanciato nel 2017, il Lenovo Yoga 720-15IKB è un computer portatile 2 in 1 con quattro orientamenti possibili in cui usarlo.
7 Domande Visualizza tutte
Lenovo Yoga 720 15ikb: SSD JIS #1 screw replacement
I own a Lenovo Yoga 720 15ikb that's SSD has a JIS #1 screw. I may have stripped it with a Phillips head screwdriver. I am working getting the correct screwdriver for it. If it is too stripped is there anywhere or anyhow I can replace the screw even if it's not a JIS?
Questa è una buona domanda?
Punteggio 0
Aggiungi un commento
1 Risposta
Soluzione Prescelta
Yes, of course, get the correct screw driver.
Steady your work and exert firm but cautious pressure sensing when the srcew driver is engaging the screw.
When putting it back in just tighten firmly but NOT too tight! Many people exert too much force.
Punteggio 1
1 Commento:
Yes, I got this a bit late and apparently I am one of those that pushes too hard. I read this, attempted to loosen it and that's when I stripped it. For now, I don't see myself needing to remove it any time soon, so I suppose I'll need to cross that bridge when I come to it. Thank you for your answer.
I also came across another post in another repair guide that said a good replacement for this computer would probably be a Phillips M2x3mm give or take .5mm.
da
Aggiungi la tua risposta
Andria Olivier sarà eternamente grato.
Visualizza Statistiche:
Ultime 24 Ore: 1
Ultimi 7 Giorni: 1
Ultimi 30 Giorni: 7
Tutti i Tempi: 245
