Salta al contenuto principale
Lanciato il 22 settembre 2017. Modelli A1864, A1897. Disponibile in versioni GSM o CDMA / 64 o 256 GB / gold, silver e space gray.
Home button is not working
I can’t tell if the home button cable is broken or not and if it is how could I fix it?
Questa è una buona domanda?
Punteggio 0
Aggiungi un commento
1 Risposta
Soluzione Prescelta
hello Ryan,
depending on the fault, sometimes HB flex is possible for fix. If you haven’t experience, find a good repair shop.
In the meantime, you can us “assistive touch” function (settings—>about—>availability—>assistive Touch—> switch on). It’s kind of emulation of your home button built in IOS. Unfortunately, you will temporarily lose touch ID functionality.
  • regards,
Punteggio 1
1 Commento:
Thank you so much
da
Aggiungi la tua risposta
Ryan sarà eternamente grato.
Visualizza Statistiche:
Ultime 24 Ore: 0
Ultimi 7 Giorni: 0
Ultimi 30 Giorni: 0
Tutti i Tempi: 66
