Salta al contenuto principale
Repair information and guides for the 2015 Retina MacBook Air. Model A1534
Keyboard and trackpad not working
Hi, I have a 2015 12” Macbook with the keyboard and trackpad not working. It works fine with an external keyboard but the built in keyboard does not work.
What is the issue? and is the fix cheap and easy?
Questa è una buona domanda?
Punteggio 1
Aggiungi un commento
1 Risposta
Sadly you’ll need to replace a major assembly to get your keyboard working again MacBook 12" Retina (Early 2015) Upper Case with Keyboard. Review this guide on what it will take to replace it Retina MacBook 2015 Upper Case Assembly Replacement. You may also need a new trackpad as well.
Immagine Replace an upper case compatible with the Early 2015 model A1534 MacBook 12 inch Retina laptop. Includes the keyboard and dual microphones.
Prodotto
$184.99
Punteggio 0
Aggiungi la tua risposta
Quinn sarà eternamente grato.
Visualizza Statistiche:
Ultime 24 Ore: 0
Ultimi 7 Giorni: 1
Ultimi 30 Giorni: 1
Tutti i Tempi: 126
