Salta al contenuto principale
Released on July 21, 2011. Core i5 or Core i7 Processor. Thunderbolt. This unit is also used to run the Mac mini Server configuration.
204 Domande Visualizza tutte
Second hard drive cable included on all models of 2011 mini?
I understand that the Server model is only available in a 2 drive configuration. Therefore it must have both cables. Also, the base model $599 version is only available from Apple as a single drive. Therefore it is definitely Not included.
So, the question is, will a $799 mini that is configured from Apple in a single-drive configuration include the second cable as well, or not?
Questa è una buona domanda?
Punteggio 1
Aggiungi un commento
1 Risposta
Soluzione Prescelta
No, unfortunately Apple has decided not to include the proprietary second hard drive cables in their non-server models. Luckily, we include them in our dual hard drive kits along with everything else you need to install a second hard drive in your Mini.
Hope this helps!
Immagine Mac mini Dual Drive Kit
Prodotto
$26.99
Punteggio 3
4 Commenti:
Thanks for the info! I figured this would be the case.
da
When do you expect the kit to be back in stock?!
da
Yeah it would be great to know when the kit is expected to be available again. Otherwise I need to purchase all the pieces elsewhere which is a pain. Thanks
da
Jake, just to be absolutely sure I'm understanding: is your double drive kit compatibile with the entry-level mini? The one only sold with a single drive?
Also, is the kit available in Europe? Or, can it be purchased directly from you?
Thank you very much,
Paolo
da
Aggiungi la tua risposta
armandotechgeek sarà eternamente grato.
Visualizza Statistiche:
Ultime 24 Ore: 1
Ultimi 7 Giorni: 1
Ultimi 30 Giorni: 1
Tutti i Tempi: 7,581
