Where is the egr valve located on 1998 mazda 626
where is the egr valve located on 1998 mazda 626
Questa è una buona domanda?
It's underneath the throttle body. Round in shape, has an electrical connector for the EGR lift sensor and a vacuum line is connected to it. Check the attached diagram. I would definitely clean it first and make sure that your vacuum lines do not have a leak before replacing it. No a common part that wears out. Hope this helps, good luck.
Ultime 24 Ore: 0
Ultimi 7 Giorni: 2
Ultimi 30 Giorni: 4
Tutti i Tempi: 5,001
1 Commento
Thank you for accepting my answer and good luck to you.
da oldturkey03
