Salta al contenuto principale
L'aggiornamento di marzo 2015 del MacBook Air da 11" di Apple offre processori Intel Core i5 e i7 di quinta generazione, con un leggero aumento delle prestazioni e della durata della batteria.
Trackpad and Keyboard not Responding. Reference Code: NDR001
Hi everyone,
I’ve recently replaced my display for my MacBook Air. And when I turned it on, the keyboard and trackpad (both built-in) was not responding.
I’ve plugged in a USB mouse and keyboard and it was working fine. Everything else (e.g. the power button, Wi-Fi, bluetooth, webcam, etc) is also working fine.
I also ran a hardware diagnostic test and it gave me reference code NDR001 & NDK001, telling me: There may be an issue with the trackpad.
I’ve also replaced the trackpad cable (pics provided).
I’ve tried replacing the trackpad cable, resetting the PRAM, and SMC. I’m not sure what the issue is.
Thanks everyone
EDIT: Some additional pictures
Questa è una buona domanda?
Punteggio 1
Aggiungi un commento
1 Risposta
Soluzione Prescelta
To me it looks like the logic board cable connector is damaged!
Update (10/27/2020)
This is the damaged connector
Compared with this one
Punteggio 1
3 Commenti:
would this mean that I would need to replace the logic board?
da
@m0nsterr - Here's a replacement connector IPD trackpad flex cable connector You do need good soldering skills to do this.
da
Thanks! Also, would this be the one on the trackpad or the logic board?
da
Aggiungi la tua risposta
Michelle L sarà eternamente grato.
Visualizza Statistiche:
Ultime 24 Ore: 3
Ultimi 7 Giorni: 6
Ultimi 30 Giorni: 14
Tutti i Tempi: 1,531
