Salta al contenuto principale
The OnePlus 6T is an Android smartphone made by OnePlus. It was announced on October 29, 2018 and released on November 6, 2018.
26 Domande Visualizza tutte
The guides are missing the part where you put back the back cover
  • Do you have to buy an adhesive?
  • Do you have to apply fresh silicon ?
  • Do the new back covers come with pre-applied adhesive or silicon ?
  • Does the existing material of the old back cover glue back if heated ?
Thanks
Questa è una buona domanda?
Punteggio 0
Aggiungi un commento
1 Risposta
Risposta Più Utile
Typically you peel off the old adhesive and replace it with new stuff. Don’t use silicone, use something like Tesa black tape. Some parts suppliers will sell precut adhesive for most devices. Some suppliers will also sell back covers with new adhesive either already attached or you need to apply it. In some cases, if you cut through the adhesive clean enough you can reuse it. Just put the back cover back on, use some heat from a heat gun or hair dryer, and then either clamp it down for about 20 minutes or put some heavy books on it.
Punteggio 1
Aggiungi la tua risposta
kriegalex sarà eternamente grato.
Visualizza Statistiche:
Ultime 24 Ore: 0
Ultimi 7 Giorni: 1
Ultimi 30 Giorni: 2
Tutti i Tempi: 147
