Salta al contenuto principale
iPhone con schermo da 4" introdotto nel marzo 2016 con specifiche hardware simili a quelle dell'6s. Disponibile in Argento, Oro, Grigio siderale, Oro rosa con 16 o 64 GB. Modelli A1662 e A1723.
No backlight NO Image problem
Hello Guys! This is an advanced question.
iPhone SE NO backlight and NO image. I have already replaced every components on the backlight line (filters, diods, IC)
The Original screen is working for SURE (tested it)
Mainboard connectors are all tested good.
Phone works, and boots I know because when I plug in the charger cable the charging sound comes in.
What is the next step to do to further investigate?
Blow photos are taken right after I opened up the phone:
Update (11/24/2020)
Thank you for taking the time for answering. Unfortunately I have decided to stop investing time for now. I have other stuff to do so I’ll put it for side now. :)
Questa è una buona domanda?
Punteggio 0
2 Commenti
How is the display driver?
da
@mrgeek Display driver has been changed to a new one.
da
Aggiungi un commento
1 Risposta
Soluzione Prescelta
Forget about the backlight until you have image. You said mainboard connectors all tested well. So you are getting
·         1V8 on pin 5?
·         5V7 on pin 1 and 3?
What are diode readings of pin 7 and 9?
Punteggio 4
Aggiungi la tua risposta
Peter Hupuczi sarà eternamente grato.
Visualizza Statistiche:
Ultime 24 Ore: 11
Ultimi 7 Giorni: 17
Ultimi 30 Giorni: 25
Tutti i Tempi: 584
