Salta al contenuto principale
1.83 GHz Core Duo or 1.83, 2, or 2.16 GHz Core 2 Duo A1208 (EMC 2104/2110/2114/2124)
201 Domande Visualizza tutte
Why is my hard drive not recognized?
I installed a crucial MX500 SSD on my 17" iMac Core Duo computer. I created a bootable USB for macOS X Catalina. When I start up the computer holding down the option key, an image that says “Install macOS Catalina” appears and after clicking it, nothing happens. I waited all night and nothing.
Please help.
Thanks in advance.
Questa è una buona domanda?
Punteggio 0
Aggiungi un commento
1 Risposta
Soluzione Prescelta
The EMC 2104 is limited to
Pre-Installed MacOS:X 10.4.4 (8G1165)Maximum MacOS:X 10.6.8*
Go here and look up your machine and it will tell you the highest operating system your machine will take.
https://everymac.com/ultimate-mac-lookup...
Punteggio 2
2 Commenti:
Thanks a lot! I'll try it and let you know.
da
@ruvelsa - Sadly the Crucial MX500 SSD won't work in your system as the systems SATA port is only SATA I (1.5 Gb/s) You'll need to use a Samsung 860 EVO SSD unlike the Crucial drive which is a fixed SATA III (6.0 Gb/s) the Samsung is auto sense so it will dial down the data rate to what the system can support in this case SATA I (1.5 Gb/s).
da
Aggiungi la tua risposta
Ruben Velez sarà eternamente grato.
Visualizza Statistiche:
Ultime 24 Ore: 2
Ultimi 7 Giorni: 3
Ultimi 30 Giorni: 4
Tutti i Tempi: 54
