Salta al contenuto principale
iPod touch 3g can only use with wall charger.
hi guys i have an ipod touch 3rd gen and i can only turn on when i connect to the wall charger and if i disconnect its turn off and the other thing that he make is that when im using whit the wall charger appears the button that say slide to power off or if he dont say this he make like i put to sleep and the i need to hit the home button to slide to unlock and he does alot of time so i think that the battery is bad and i dont know if the power or sleep button is bad soy can help me please? thanks...
Questa è una buona domanda?
Punteggio -1
Aggiungi un commento
2 Risposte
Soluzione Prescelta
gmaincomputerservice, I'd start with the battery first. The reason why you can't start it any other way is because the battery does not hold a charge the way it should. The AC charger supplies more amperage to the iPod. start with the battery, then reevaluate for other damage. It is my experience that be trying to fix more than one thing at the time, the trouble shooting gets confusing..Good Luck and let us know how it is going.
iPod touch (3rd Gen) Battery
Sostituzione batteria iPod Touch 3a generazione
Immagine iPod touch (3rd Gen) Battery
Prodotto
$14.99
Punteggio 1
thanks
Punteggio 0
Aggiungi la tua risposta
gmaincomputerservice sarà eternamente grato.
Visualizza Statistiche:
Ultime 24 Ore: 1
Ultimi 7 Giorni: 1
Ultimi 30 Giorni: 1
Tutti i Tempi: 1,383
