Salta al contenuto principale
The 5th Generation Hilux introduced in 1988, produced a longer-wheelbase option, 3,099 mm (122 in) rather than 2,616 mm (103 in) for the regular wheelbase. Its one-piece cargo-box walls eliminated the rust-prone seams that were found in earlier models.
5 Domande Visualizza tutte
1994 Toyota 22re PU It's Crank, but no turn over.?
everything sound ok check alround crank and crank bud no turn on…please help.
Questa è una buona domanda?
Punteggio 0
2 Commenti:
multitasking974 exactly what have you checked? Do you have fuel going into the cylinders? Do you have spark when the engine turns over? did you check your oil level? Is it sufficient?
da
i checked out everything you ask....nothing...and mechanic around here want lot of $ just for checking.
da
Aggiungi un commento
1 Risposta
check the timing gear
Punteggio 0
Aggiungi la tua risposta
multitasking974 sarà eternamente grato.
Visualizza Statistiche:
Ultime 24 Ore: 1
Ultimi 7 Giorni: 17
Ultimi 30 Giorni: 28
Tutti i Tempi: 585
