Salta al contenuto principale
Rilasciato il 16 settembre 2016. Modelli 1660, 1774 e A1785. Disponibile come GSM o CDMA / 32, 128 o 256 GB / Rose gold, gold, silver, black e jet black.
1364 Domande Visualizza tutte
How do I know my dead phone needs a battery or a screen
I opened the device for cleaning purpose and it was working when I tried it after opening the device, then I turned it off and cleaned the edges of the battery (I didn't touch the right side of the battery) I encountered some
Problems when installing the screen and after that I tried to start the device not working, so is the problem from the screen battery? (I didn't touch anything else, the left side of the battery and the screen only returned) + When charging the phone, I feel, but the electricity is in the back, as usual
Questa è una buona domanda?
Punteggio 0
Aggiungi un commento
1 Risposta
Soluzione Prescelta
The problem is with the screen. Its connection is not working properly. The battery doesn’t affect in any type of cleaning except you dip it in the water or it catches the moisture.
Punteggio 1
1 Commento:
Thank you. I tried my Airpods near the device and I heard the pairing sound
Although there is no sound or vibration when charging the phone or changing the sound pattern
da
Aggiungi la tua risposta
Senpai sarà eternamente grato.
Visualizza Statistiche:
Ultime 24 Ore: 0
Ultimi 7 Giorni: 1
Ultimi 30 Giorni: 1
Tutti i Tempi: 58
