Salta al contenuto principale
The Volvo XC90 is a mid-size luxury crossover SUV manufactured by Volvo since 2002 and now is in its second generation.
Why is my SUV chugging in idle?
My SUV keeps chugging when coming to a stop and idling. It is fine while I’m driving. The rpm gauge jumps up and down slightly in idle as well. I was told to use Mystery Motor Oil. Any suggestions? Thanks.
Questa è una buona domanda?
Punteggio 0
2 Commenti
Any engine light or codes? Sometimes the coil packs get wonky and only work when the cpu asks for higher rpms. Used to own many volvos and fixed them regularly.
da
@caleymac what exact year and engine size is your Volvo? Besides "Mystery Motor Oil, what have you tried? How is your gas mileage? Has it gone up drastically? How is the performance when not at idle?
da
Aggiungi un commento
2 Risposte
Risposta Più Utile
Rough idling can be caused by clogged filters. ... Bad spark plugs, bad spark plug wires and a bad distributor cap are other common causes of rough idling. These items are all important parts of what keeps a vehicle running. Spark plugs provide the spark that ignites the air and fuel mixture within the cylinders.
Punteggio 1
It’s the throttle body dirty I had mine like that even at a stop sign shuts off . Took it off and cleaned it with throttle body cleaner from autozone now it idles like brand new
xC90 2006
Punteggio 0
1 Commento:
That makes sense. It wouldn't trip a code either.
da
Aggiungi la tua risposta
CaleyMac sarà eternamente grato.
Visualizza Statistiche:
Ultime 24 Ore: 0
Ultimi 7 Giorni: 1
Ultimi 30 Giorni: 18
Tutti i Tempi: 937
