Salta al contenuto principale
Modelli A1419 / Fine 2012 / Processori 2.9 & 3.2 GHz Core i5 o 3.4 GHz Core i7, ID iMac13,2
330 Domande Visualizza tutte
How to identify GPU on iMac 27 2012 board?
I have a working logic board from 2012 27” iMac, how to identify which GPU it has?
I know it is not 512MB one since there are 8 chips installed along side it, so if anyone could help me, would appreciate that!
Thank you!
Questa è una buona domanda?
Punteggio 0
Aggiungi un commento
1 Risposta
Soluzione Prescelta
Apple offered three versions of GPU’s in this series
2.9 GHz Core i5 (I5-3470S) model: NVIDIA GeForce GTX 660M with 512 MB of dedicated GDDR5 memory
3.2 GHz Core i5 (I5-3470) & 3.4 GHz Core i7 (I7-3770) offered two options:
  • NVIDIA GeForce GTX 675MX with 1 GB of dedicated GDDR5 memory
  • NVIDIA GeForce GTX 680MX with 2 GB of dedicated GDDR5 memory *
, * For an extra US$150 at time of purchase.
Punteggio 1
4 Commenti:
Thanks Dan, but how to identify it if I have logic board only?
da
You need to use a little logic here ;-}
So as you don't have all of the RAM installed (empty pads) we know you don't have the first: 2.9 GHz Core i5 (I5-3470S)
So then that leaves us with either the other two. The more probable is the NVIDIA GeForce GTX 675MX as the other is a special order item at a higher cost.
You could look up the DDR5 RAM specs or If you want to be 100% then you'll need to remove the heat sink to read the GPU chips markings. The logic board ID is the same across all three boards so that won't help you and the board S/N label would be the only other way but it could be doctored or missing.
da
@danj, on the chip it says Nvidia 1237A2 TOF468.M01 / N13E-GT-W-A2
da
Then the NVIDIA N13E-GTX-A2 chip marking tells us you have a GeForce GTX 680M GPU board.
da
Aggiungi la tua risposta
Yurii Suhov sarà eternamente grato.
Visualizza Statistiche:
Ultime 24 Ore: 0
Ultimi 7 Giorni: 0
Ultimi 30 Giorni: 5
Tutti i Tempi: 291
