MacBook Air screen is flickering and fading.
I think this video is self -explanatory.
Any idea?
Questa è una buona domanda?
Any idea?
You have a damaged LCD panel. There are a set of fragile connections from the LCD to the T-CON board which have been damaged. So as you move the display you are allowing the connections to make and break.
Here’s the needed part: MacBook Air 13" (Mid 2013-2017) Display Assembly and here’s the guide to put it in MacBook Air 13" Mid 2013 Display Assembly Replacement
Thanks, could I replace only the T-CON board?
Replacing the T-CON board won't help you here (and you can't replace it alone and its not the T-CON bd its the ribbon cables between) You need the full assembly.
Ultime 24 Ore: 0
Ultimi 7 Giorni: 2
Ultimi 30 Giorni: 2
Tutti i Tempi: 58
