Salta al contenuto principale
13" aluminum unibody, 2.0 or 2.4 GHz Core 2 Duo processor.
574 Domande Visualizza tutte
Keyboard and Trackpad not working.
Hello.
I have a Macbook Pro that has had some liquid split on it, it was not a lot and it was immediately stripped and dried. It has since been put back together but neither the track pad or the key board are working.
Any advice on how to repair this issue would be great!
Thank you.
Questa è una buona domanda?
Punteggio 0
2 Commenti:
Does an external USB or Bluetooth keyboard and mouse work?
da
I've not tested Bluetooth but USB works fine. Thank you.
da
Aggiungi un commento
1 Risposta
At this point you’ll need to replace the keyboard and trackpad as they are damaged from the spill. Hopefully its limited to the parts alone.
The easiest way is just replacing the full uppercase Top Case with Non-Backlit Keyboard, Apple P/N 661-4943 and Trackpad MacBook Unibody (A1278) Trackpad, Apple P/N 922-9014 and here’s the guide MacBook Unibody Model A1278 Upper Case Replacement
Immagine MacBook Unibody (A1278) Trackpad
Prodotto
$64.99
Punteggio 0
Aggiungi la tua risposta
chris.j.rose sarà eternamente grato.
Visualizza Statistiche:
Ultime 24 Ore: 1
Ultimi 7 Giorni: 1
Ultimi 30 Giorni: 1
Tutti i Tempi: 71
