Salta al contenuto principale
Repair guides and support information for RCA-brand tablets.
Charging and stuck on start screen
When I plug my tablet in both with its own charger and my USB it says charging but when I try turning it on I get a yellow triangle with an exclamation point over the battery at first it was stuck on the start screen and would not g anywhere after rebooting it now it will not turn on even with charger plugged in
Questa è una buona domanda?
Punteggio 0
1 Commento
@lgu97701 what is the exact model of your RCA tablet?
da
Aggiungi un commento
1 Risposta
Risposta Più Utile
@lgu97701 sounds like you either have a bad battery or a bad charging port/charger. Check the voltage on the charger. If that works I would consider replacing the battery and while you are doing that inspect the charging port to ensure it does not have any broken pins etc., and is still properly connected.
Punteggio 1
Aggiungi la tua risposta
LaShayla Gunn sarà eternamente grato.
Visualizza Statistiche:
Ultime 24 Ore: 0
Ultimi 7 Giorni: 0
Ultimi 30 Giorni: 0
Tutti i Tempi: 138
