Salta al contenuto principale
Repair and disassembly guides for GE Microwave ovens.
No Buttons Work on the Control Panel?
My control panel is saying "Set clock" but none of my buttons will work. I took it off so I could clean it really good and when i Hooked it up the control Panel started say to set the clock but no buttons will do anything., I unhooked it again and tried but it did the same thing. I unplugged it for a while then replugged but the same thing. When I took it apart the first time I forgot to unplug it first so, did that do something to it? It shouldn't have. I didn't get anything wet . I'm Baffled...PLEASE HELP
Questa è una buona domanda?
Punteggio 0
Aggiungi un commento
2 Risposte
Soluzione Prescelta
the general agreement amongst ifixit members is to throw it away. Any repair attempts aren't worth the potential damage to yourself or your home should you try it. Microwaves are cheap to replace (ish)
Punteggio 4
3 Commenti:
That is the easy way out... where is the challenge of doing something and learning from it. to say " I fixed it myself"!!!
We are in such a "throw it away" society that we are causing many problems for our self.
da
Daniel Martinez, when it comes to Microwaves and CRT's we are all a little bit more careful on here. those things have a tendency of giving people a nasty shock if not handled properly. You are partially right with your statement, but safety must come first. I don't think that it is an easy way out, just a very safe way.
da
repairing of appliances needs general knowledge, it is a kind of hobby, challenge, please.
da
I know this thread is old but in the case anyone comes a across this issue like I did, I found the easiest solution was to just send it to applianceboardrepair and have them repair it. Might just be a better option for some people when they're unable to repair it themselves rather than throwing it away.
Just my 2 cents
Punteggio 0
Aggiungi la tua risposta
Carol Hughes sarà eternamente grato.
Visualizza Statistiche:
Ultime 24 Ore: 0
Ultimi 7 Giorni: 3
Ultimi 30 Giorni: 8
Tutti i Tempi: 6,834
