Salta al contenuto principale
Annunciato nell'agosto 2017, il Galaxy Note8 è il successore del Galaxy Note7 ritirato dal mercato ed è stato commercializzato a partire da settembre 2017.
Poor performance after battery replacement
I replaced my battery with a new part from a reputable UK seller, and the device continued to operate fine for two weeks, however the battery calibration appeared to fail a couple of days ago and now the device is running at approximately 1% of the expected performance when on battery (5+ minutes to boot as opposed to a few seconds), and yet when connected to the charger it runs fine again. Do I have a faulty battery?
Questa è una buona domanda?
Punteggio 0
Aggiungi un commento
1 Risposta
Risposta Più Utile
Alistair,
Good afternoon! I have seen this issue many times with replacement batteries. More than likely you did get a defective battery. Check with the seller to see what their warranty period is and try to get a replacement. I just had a note 8 do this same thing a few weeks ago. Hope this helps!
Roy
Punteggio 1
1 Commento:
Thanks Roy, I was hoping this wasn’t the solution but I’m inclined to agree with you - Back through the layers of adhesive again I guess!
da
Aggiungi la tua risposta
Alistair McShee sarà eternamente grato.
Visualizza Statistiche:
Ultime 24 Ore: 2
Ultimi 7 Giorni: 8
Ultimi 30 Giorni: 18
Tutti i Tempi: 175
