Salta al contenuto principale
A1708 / EMC 3164 — Lanciato a giugno 2017, questo MacBook Pro entry-level conserva i tradizionali tasti funzione (invece della Touch Bar OLED.
563 Domande Visualizza tutte
Neither the keyboard backlight or caps lock light indicator work.
I have a 2017 13” function keys MacBook Pro and the keyboard is giving me a hard time. Some of the keys on the right side are sticky, the backlight doesn't work at all and the caps lock light indicator doesn’t light up either. Could this be because of the keyboard cable, a motherboard problem or could it be the actual keyboard? I called Apple and they said they could address the sticky keys since they have a program for it but, this wouldn’t address the keyboard backlight and that the computer is out of warranty. Should I go ahead and try the program and see what happens? Does anyone here have any idea what could be the problem? Mainly for the keyboard backlight and caps lock light.
Questa è una buona domanda?
Punteggio 0
Aggiungi un commento
1 Risposta
The symptoms you’ve described do sound like a liquid spill related problems, so before going to Apple I would still open my A1708 and check all those water indicators inside just to be sure that it is not it.
The Keyboard replacement will fix only keyboard (including its cable) related problems, but it is worth a try.
Though, if there was a spill, there could be a list of other issues manifesting itself just like that. I would look for any sign of oxidation on the motherboard and decide what to do next from the results of that inspection.
Good luck
Punteggio 0
Aggiungi la tua risposta
Genesis Soto sarà eternamente grato.
Visualizza Statistiche:
Ultime 24 Ore: 2
Ultimi 7 Giorni: 5
Ultimi 30 Giorni: 10
Tutti i Tempi: 192
