Salta al contenuto principale
Repair guides and troubleshooting for HP Pavilion dv7 laptops, manufactured by Hewlett-Packard starting in 2008, and featuring a 17.3" diagonal display.
137 Domande Visualizza tutte
fv 274 av dc jack
I have a dv 7 fv 274 av and think it may be the problem and want to make sure not to get the wrong part . When plugged in if I play around I can get a light showing it is on and charging, the slightest movement and the light goes out. If I try to power it up the light goes out, When I don’t touch it and the light goes on the battery charge but not completely. Somehow the os is now corrupted and I can not get the computer to stay on long enough to do a repair of the system. My thought was a correct replacement of the jack might lead to be able to use the machine again.
Questa è una buona domanda?
Punteggio 0
Aggiungi un commento
1 Risposta
Risposta Più Utile
murohyg27 this sentence in your description “When plugged in if I play around I can get a light showing it is on and charging, the slightest movement and the light goes out. If I try to power it up the light goes out “ would lead me to changing the DC in jack first. This video should be pretty similar to your system. Of course, you can download the service manual from here
Punteggio 1
Aggiungi la tua risposta
murphyg27 sarà eternamente grato.
Visualizza Statistiche:
Ultime 24 Ore: 1
Ultimi 7 Giorni: 3
Ultimi 30 Giorni: 4
Tutti i Tempi: 58
