Salta al contenuto principale
Released September 2016. Identified by Model No. SM-G610
j7 prime is not recognized by PC when connected but charger works.
My pc does not recognize my j7 prime, l tried different usb cables, computers, l got the same results. could it be that the usb port on j7 is faulty ? by the way, the charger works just fine using different usb cables.
Questa è una buona domanda?
Punteggio 2
Aggiungi un commento
1 Risposta
Risposta Più Utile
@kevin49 if your setting on your phone and your computer have not changed it should be recognized. IF it does not then I would suspect this to be an error of the port. Yes, it may still charge since that is all part of a different circuit. Disassemble your phone and take a look at the connector. You can uses a multi-meter to measure for continuity from the cable to where the connector connects to the board.
Punteggio 1
Aggiungi la tua risposta
Adam Ward sarà eternamente grato.
Visualizza Statistiche:
Ultime 24 Ore: 0
Ultimi 7 Giorni: 4
Ultimi 30 Giorni: 11
Tutti i Tempi: 1,134
