Salta al contenuto principale
Lo smartwatch Apple di quarta generazione, con connettività cellulare opzionale, lanciato il 21 settembre 2018.
124 Domande Visualizza tutte
Apple Watch unpairing during setup
Recently I’m facing this issue after erase my watch while connecting it was unpairing getting pop up like bring both devices closer. I tried with several iPhones but no luck.
Here no repair in my country from Apple care it was out of warranty
Note :Previously I replaced the glass on screen
From that day it was started very slow booting. Then after erase got this issue
How can I fix this?
Please help me
Questa è una buona domanda?
Punteggio 0
1 Commento:
Did you transfer the NFC module from your old display to the new one?
da
Aggiungi un commento
1 Risposta
On certain generations of apple watch, the force touch sensor is tied to the specific watch, I think it was the series 2, 3, and 4. If you replaced the sensor, it would work just fine with whatever phone it was paired with, but as soon as you unpaired it from that device, it would never pair with another one again.
*EDIT MUST READ*
My initial answer was incorrect. The force touch sensor is NOT paired. It’s the NFC sensor on the screen that is paired. You’ll need to transfer the original NFC sensor to the new display. If that doesn’t work, you can use the old screen to pair it with the new device then swap the new screen after it has been paired.
Punteggio 0
7 Commenti:
Thats an urban legion!
There is no serialization of the Force Touch sensor! You can encounter part failure though! As well as people try glueing the display assembly which interferes with the sensors action. The display assembly moves pressing on the sensor, if you stop it, it won't work.
da
@danj my mistake. It was the NFC sensor that's paired. I'll edit my answer.
da
@hootonberg - If you don't transfer the NFC over the next WatchOS update will kill your watch!
da
I didn’t replace the whole screen
I just replace the cracked glass on my old screen
da
@Feroz Mohammed - Then you managed to damage the display panel part in the process. Time to replace the full display assembly and transfer the NFC module over.
Sostituzione schermo Apple Watch Series 4
da
Mostra altri 2 commenti
Aggiungi la tua risposta
Feroz Mohammed sarà eternamente grato.
Visualizza Statistiche:
Ultime 24 Ore: 0
Ultimi 7 Giorni: 1
Ultimi 30 Giorni: 2
Tutti i Tempi: 220
