Salta al contenuto principale
The original Xbox is Microsoft's first widely popular video gaming system. It has an easily identifiable black case with 'XBOX' emblazoned on the top and front. Repair is easy with common tools.
171 Domande Visualizza tutte
Accidentally shorted power supply, wont power on
i finished modding my xbox and in the rush of excitement dropped my ssd onto the power board, the metal plate with holes in it, it gave me a small shock and welded the ssd to the top of it before the safety switch went off, im assuming since removing the ssd that the metal plate will be fine and ive just blown the fuse near the connector, is there any advise or suggestions to help with replacing the fuse or other things i should look at? its a 1.6 with a delta 1 row psu
the ssd is alive and just seems to have been external damage which gives me hope for the rest
Questa è una buona domanda?
Punteggio 0
Aggiungi un commento
1 Risposta
After you shorted the PSU, the fuse probably popped. Try locating the fuse and replacing it with a new fuse. If that doesn't work, then the other part of the PSU is fried and you have to replace the PSU. Hope this helps.
Punteggio 0
Aggiungi la tua risposta
matthewyeardley sarà eternamente grato.
Visualizza Statistiche:
Ultime 24 Ore: 2
Ultimi 7 Giorni: 3
Ultimi 30 Giorni: 11
Tutti i Tempi: 212
