Salta al contenuto principale
Model A1297 Unibody: Early 2009, Mid 2009, Mid 2010, Early 2011 & Late 2011
544 Domande Visualizza tutte
Issues with Thunderbolt port connect to HDMI
hi guys,
I have a 2011 MacBook and here’s the full config of the port…
Thunderbolt Bus:
  •   Vendor Name: Apple Inc.
  •   Device Name: MacBook Pro
  •   UID: 0x0001000A1BBAC1E0
  •   Route String: 0
  •   Firmware Version: 22.1
  •   Domain UUID: 9C79FF0F-ED63-FC51-8B0D-C1E08DB9C206
  •   Port:
  •   Status: No device connected
  •   Link Status: 0x101
  •   Speed: Up to 10 Gb/s x2
  •   Receptacle: 1
  •   Port Micro Firmware Version: 2.1.3
Do you have any suggestions how to make this work to connect to my Samsung TV via HDMI. thanks
Questa è una buona domanda?
Punteggio 0
Aggiungi un commento
1 Risposta
Risposta Più Utile
Hi ruchirj33,
Thunderbolt is not the same as Mini Display Port. They are only co-sharing the same port on your computer.
If you want to connect a TV via HDMI then what you need would just be a Mini Display Port to HDMI adapter.
However, if your TV has a high resolution like UHD, then this may not be supported by your system.
But: Since your problem is not Thunderbolt related, I would recommend you give us more information about your TV.
Punteggio 1
Aggiungi la tua risposta
ruchirj33 sarà eternamente grato.
Visualizza Statistiche:
Ultime 24 Ore: 1
Ultimi 7 Giorni: 2
Ultimi 30 Giorni: 3
Tutti i Tempi: 135
