Salta al contenuto principale
Modello A1224 dal metà del 2007 all'inizio del 2008 / processori Core 2 Duo a 2, 2.4 o 2.66 GHz
iMac 8.1 Screen is oversaturated also on external monitor
I got my hands on an old Imac 8.1.
The screen in standard mode is however oversaturated. I get the same result when I connect een external monitor. I was able to get it a little bit better readable screen with calibration, attached 5 pictures.
2 with the oversaturated screen
2 with the same screens now corrected a bit.
1 from my Imac 14.2 with the same backgrounds to show the difference.
Are there options to tune the graphics card or should I look for a replacement of the graphics card?
The OS is Snow Leopard
Thanks and regards,
Jacob
Questa è una buona domanda?
Punteggio 0
Aggiungi un commento
1 Risposta
First, go into System Preferences, then Displays, then click Color. You should have a lot of options listed. Click on the top one that says Color LCD. You should see the colors change. Hope this helps.
Punteggio 0
2 Commenti:
Thank you for your answer. I already did that as you can see in the picture 1 & 2. The top option (and other standars) give the over saturated view. As stated I created a calibrated one, which gives a slightly better display but still over saturated view, see picture 3 & 4.
da
@sjakio it might be the graphics card is defective or glitchy so you might want to look into gpu replacements.
da
Aggiungi la tua risposta
jacobkamminga sarà eternamente grato.
Visualizza Statistiche:
Ultime 24 Ore: 1
Ultimi 7 Giorni: 5
Ultimi 30 Giorni: 13
Tutti i Tempi: 212
