Salta al contenuto principale
La linea di computer portatili MacBook Pro di Apple per utenti avanzati e professionisti. La linea MacBook Pro include varianti da 13, 14, 15, 16 e 17 pollici, e le revisioni principali sono definite da Pre-unibody (originale), unibosy, display Retina, Touch Bar e SoC (system-on-a-chip).
20008 Domande Visualizza tutte
Random MacBook Pro shut down after replacing with ifixit battery
Since replacing the battery in my mid-2012 MacBook Pro with an ifixit.com replacement battery, it now shuts down randomly.
I’ve heard about a firmware update that could resolve this but don’t know the exact details.
Can someone share how to fix this?
Questa è una buona domanda?
Punteggio 2
1 Commento:
Which system? The unibody or the retina? The 13" or the 15"?
da
Aggiungi un commento
2 Risposte
Try updating the firmware. See if that works. If that doesn't work then try cleaning the battery contacts with some alcohol and a toothbrush (carefully). If that also doesn't work then it might be that you got a bad battery. If that's the case, then contact iFixit for a replacement battery.
Punteggio 0
I would check the CMOS battery first before blaming the main battery. This battery will cause a computer to shutdown randomly or not startup at all. I've had several computers with that problem, laptop and PC. Its an inexpensive fix and fairly easy to check on most laptops though some can be moderately difficult to get to.
Hope this helps.
Eddie
Punteggio 0
2 Commenti:
@towerjack1960 - No CMOS battery in any of the MacBook Pro systems.
da
@danj. Thank you for letting me know that. I didn't realize that. I know windows has them because I get the batteries out of junk cases each week. Haven't had a MacBook Pro in awhile, think I have one around here somewhere. What do they use for BIOS then?
da
Aggiungi la tua risposta
robotman123 sarà eternamente grato.
Visualizza Statistiche:
Ultime 24 Ore: 0
Ultimi 7 Giorni: 2
Ultimi 30 Giorni: 5
Tutti i Tempi: 132
