Salta al contenuto principale
The HP Pavilion 15 cs0xxx is a 15-inch laptop that was released as part of the HP Pavilion computer line.
Where can I get replacement hinges for HP Pavilion 15-cs0051cl?
Where can I get replacement hinges for HP Pavilion 15-cs0051cl??????? I love this laptop, but the hinge on the left is broken and the one on the right isn’t far behind!
Questa è una buona domanda?
Punteggio 0
Aggiungi un commento
1 Risposta
If you are looking for just the hinges these appear to be HP Spare Part Number L23884-001. You should be able to order these directly from HP if they have them in stock or you could do a search on Ebay to see if you can find them there as well. It might also be worth picking up a spare set of screws (L23915-001) in case you’re missing some. That could be another reason the hinges are not as tight as they should be.
Punteggio 0
Aggiungi la tua risposta
jackie12989 sarà eternamente grato.
Visualizza Statistiche:
Ultime 24 Ore: 0
Ultimi 7 Giorni: 1
Ultimi 30 Giorni: 11
Tutti i Tempi: 494
