Salta al contenuto principale
Model A1225 / Early 2009 / 2.66, 2.93, or 3.06 GHz Core 2 Duo processor
iMac does not recognize WD Blue SSD
I have replaced the HDD of my iMac by a 1T WD Blue SSD, but the computer is not recognizing the SSD. I booted from a live linux CD and the drive is not showing up on for instance lsblk. Any help would be greatly appreciated.
Questa è una buona domanda?
Punteggio 0
1 Commento:
I would suggest to check the connection. And / or test the drive in another computer/external case.
da
Aggiungi un commento
1 Risposta
This is the problem with the Fixed III SSDs in SATA II Macs like this - they do not work! You need a drive with a SATA II mode, or a Fixed II SSD.
As to what drives I’d recommend there are two:
Punteggio 0
Aggiungi la tua risposta
Tsog Gantumur sarà eternamente grato.
Visualizza Statistiche:
Ultime 24 Ore: 0
Ultimi 7 Giorni: 2
Ultimi 30 Giorni: 9
Tutti i Tempi: 269
