what's inside or pizza any1
i’m starting from scratch. I need to add a drive now. how do I “get in”?
Questa è una buona domanda?
Here’s the guide to add a drive (2nd) Installazione dell'SSD Dual Drive nell'iMac Intel EMC 2133 ed EMC 2210 da 20" I personally don’t recommend it! The Optical drives I/O is a very slow PATA connection ATA/100 (800 Mb/s). If you are thinking of adding a SSD you’ll be wasting it as the interface limits it.
The better direction is to replace the HDD Sostituzione disco fisso nell'iMac Intel EMC 2133 o EMC 2210 da 20" with a better drive. We still have an issue with this systems SATA port as its only SATA II (3.0 Gb/s) most SSD’s today are SATA III (6.0 Gb/s) and won’t work well in your system. You’ll need to find an older fixed speed SATA II (3.0 Gb/s) drive or a auto sense drive which will match the systems I/O speed. Review the drives spec sheet to make sure it lists SATA II if it doesn’t then its not able to support the slower interface.
Guida
Difficoltà:
Moderato
1 hour
Guida
Difficoltà:
Moderato
Ultime 24 Ore: 0
Ultimi 7 Giorni: 0
Ultimi 30 Giorni: 2
Tutti i Tempi: 42
1 Commento
I should have waited. I'm inside it now but lost video.
da James Walker
