Salta al contenuto principale
Annunciato nel marzo 2015 e lanciato il 10 aprile 2015, il Galaxy S6 era a quel tempo il top della gamma Galaxy. La versione con schermo curvo è nota come Galaxy S6 Edge.
20 Domande Visualizza tutte
Samsung S6 won’t turn on only showing (white led)
I’ve tried most key combos. I’m going to take this explanation from DroidGuy because it matches my exact problem. “I have a Samsung Galaxy S6. I had it hooked up to the charger all night, woke up the next morning, saw that the battery icon was full and green. When I went to turn it on, the whole screen went black and I have not been able to get it running again since. I tried all the troubleshooting there is, still nothing. The only thing that happened is a solid white LED light.“ The phone has a lot of sentimental value to me and it’s not an option to take to the store help?
Questa è una buona domanda?
Punteggio 2
2 Commenti
you fix this? i have the same problem
da
I’ve just found my old Galaxy again which has this exact problem. Still no way to fix this?
da
Aggiungi un commento
5 Risposte
Risposta Più Utile
I have this problem on the s6 edge+. phone boots up and after a minute it freezes and then shuts down or restarts with the white led on. Cannot use it for more than a minute unless i constantly engage the digitiser(by drawing a 0 on the screen or in a pencil erasing motion). So i’m guessing this issue could be a display shorting or something related to the display connector.
Punteggio 1
try using another charger or if that doesnt work do a master reset usually when u gimet the white light its a sign battery is dead
Punteggio 0
2 Commenti:
Hi... I have the same issue ... but in desperation I banged it a little then it worked for few hours and now it’s back to the white solid light ... I tried the same trick again and it is just stuck at the Samsung boot up screen. Frustrated ... wonder if someone can help please as I also have a lot of memories saved up in that phone and I don’t want to completely erase it until I have the memories backed up. Any help please ?
da
has anyone figured out what the solution is
da
After you turn on the phone, you don't need to do anything. After a period of time, the device may be able to boot normally. This is one method I have tried.
Punteggio 0
It happened to me now and it happened previously. Just wait for the charging to end and then it will open
Punteggio 0
1 Commento:
sorry what do you mean, charge it fully then it will turn on? thanks
da
This problem is related to a hardware issue.
Could range anything from NAND/UFS failure or issues with the RAM or anything.
Samsung hasn't documented anything on this.
I'm still working out what it could mean.
Punteggio 0
Aggiungi la tua risposta
Fix S6 sarà eternamente grato.
Visualizza Statistiche:
Ultime 24 Ore: 3
Ultimi 7 Giorni: 17
Ultimi 30 Giorni: 73
Tutti i Tempi: 10,178
