Salta al contenuto principale
Rilasciato il 16 settembre 2016. Modelli 1660, 1774 e A1785. Disponibile come GSM o CDMA / 32, 128 o 256 GB / Rose gold, gold, silver, black e jet black.
1364 Domande Visualizza tutte
How can I wipe a locked logic board?
So I am replacing a logic board on an iPhone 7 Plus and I find a cheap logic board on eBay for less than $40. Come to find out, it is locked. I have tried YouTube/Googling and have yet to find a method that will allow me to get past the required lock screen which displays the limited email address. I get it into recovery mode > Restore and Update > Lock Screen. Other methods require me to manually enter DNS addresses but like I said, nothing.
Help!!!
Questa è una buona domanda?
Punteggio 0
Aggiungi un commento
2 Risposte
Risposta Più Utile
You can’t. Also keep in mind when buying a new logic board such as that one your eyeing on eBay it won’t work with your existing touch id sensor, this is because they are paired at the factory.
Punteggio 1
As Reece said there’s no technical real fix to a iCloud locked board as Apple will always see the S/N as locked. However if you really need it to work you can use a tool called Checkra1n then pay to get service working as well as being untethered. The service is called sonick14, keep in mind if you restore the phone with a computer it will become ic locked again.
Punteggio 0
1 Commento:
Yes this is possible, but thats jail breaking. If you want to do it all clean you would have to buy a logic board fingerprint sensor combo.
da
Aggiungi la tua risposta
boxerbc sarà eternamente grato.
Visualizza Statistiche:
Ultime 24 Ore: 1
Ultimi 7 Giorni: 2
Ultimi 30 Giorni: 6
Tutti i Tempi: 352
