Salta al contenuto principale
La decima generazione del "phablet" Samsung, con stilo S Pen. Rilasciato nell'agosto 2019.
What is the recommended solution for pixelation on the screen?
Right where the URL bar is when I'm using chrome or any other browser towards the far right there is a spot that looks like it's pixelated - a very small line that is at a 45 degree angle from the x axis and about a quarter of an inch thick. What parts should I buy to fix it and which tools will I need?n
Questa è una buona domanda?
Punteggio 0
1 Commento:
Can I get a picture please
da
Aggiungi un commento
1 Risposta
It looks like the screen is damaged and will need to be replaced or you can live with it.
Punteggio 0
1 Commento:
How much would it cost to replace the screen ? Because I'm trying to sell it and it is perfect minus the small pixelation. Also I imagine I would need some special tools to accomplish the job, I'm am engineer but I work mostly in design but it seems like it would be straight forward (if time consuming) with the proper equipment. Suggestions? Also it should be mentioned that the area of the screen identified is the only problem area and often it will disappear and work fine. It never exacerbates the display issue and is confined to the small space identified.
da
Aggiungi la tua risposta
Def Jaring sarà eternamente grato.
Visualizza Statistiche:
Ultime 24 Ore: 0
Ultimi 7 Giorni: 1
Ultimi 30 Giorni: 4
Tutti i Tempi: 124
