Salta al contenuto principale
Lanciato il 4 novembre 2017. Modello A1865, A1901. Disponibile con GSM o CDMA / 64 o 256 GB / Colore Silver o Space Grey. Si pronuncia "iPhone 10".
1199 Domande Visualizza tutte
iPhone X screen replacement cables TOO LONG?
Hey.
I hope someone can help me because I have been stuck for days.
My iPhone X needed a screen repair, so I bought a so called OEM screen.
this OEM screen has longer cables, But Also thicccer cables that the original screen. When I was assembling the screen, part of the folded cable stuck out from the iPhones frame, and it still does. I really need help on how I can keep the cable from sticking out, because I cant fit the screen correctly.
Any answers are highly appreciated
thankk yu
Questa è una buona domanda?
Punteggio 0
Aggiungi un commento
2 Risposte
Risposta Più Utile
If you look beside the mother board on the power button side there will be a little space where the cables can curl down and sit in there.
Punteggio 1
1 Commento:
thanks man you saved my day
da
The bottom cables can slide under the screen. Do ut slowly.
Punteggio 0
Aggiungi la tua risposta
Ted Olsen sarà eternamente grato.
Visualizza Statistiche:
Ultime 24 Ore: 2
Ultimi 7 Giorni: 2
Ultimi 30 Giorni: 2
Tutti i Tempi: 71
