Salta al contenuto principale
Il decimo telefono di Samsung della serie top Galaxy S, lanciato a marzo 2019. Dotato di Android 9.0 (Pie).
71 Domande Visualizza tutte
My screen is destroyed. Can it be fixed or my photos salvaged.
It fell and landed square on a rock the damage went through the screen to the point that I can see a bit of the guys. Is it fixable? At least to the point of getting my pictures off of it
Questa è una buona domanda?
Punteggio 0
Aggiungi un commento
1 Risposta
You will have to put a screen on it to find out. Most likely it can be fixed. If you are going to do it yourself buy a good quality screen WITH A FRAME. It makes it a lot easier to change and you don't to worry about sealing the screen because it already attached. You got heat up the back and cut the glue on the back battery cover around the edge with something thin like a guitar pic. Remove the mid frame with a bunch of Phillips screws then a couple of screws and the motherboard and misc electronic parts. You can get multiple repair videos on YouTube and swap everything over. You may need a new rear cover if you crack it but it's only a few dollars. If you don't think you can do it or don't want to you can check with a local repair shop or you can mail it in. The two people I recommend is jessa at ipad rehab ipadrehab.com or Jason at sts telecom ststelecom.com. I hope that helps.
Punteggio 0
Aggiungi la tua risposta
TYLER COWIE sarà eternamente grato.
Visualizza Statistiche:
Ultime 24 Ore: 2
Ultimi 7 Giorni: 4
Ultimi 30 Giorni: 4
Tutti i Tempi: 53
