Salta al contenuto principale
iPhone con schermo da 4" introdotto nel marzo 2016 con specifiche hardware simili a quelle dell'6s. Disponibile in Argento, Oro, Grigio siderale, Oro rosa con 16 o 64 GB. Modelli A1662 e A1723.
1049 Domande Visualizza tutte
Vertical red lines on screen replacement
Just installed my screen replacement and when I power on device to check it there are red vertical lines one the screen. I triple checked the lcd cable and it is properly attached. What could it be.
Questa è una buona domanda?
Punteggio 0
Aggiungi un commento
2 Risposte
First disconnect the battery then check the connections for any damaged pins, use a magnifying glass. If the connection is fine clean the connectors with a qtip and alcohol and a soft brush. Make sure you have a good connection. If that doesn't fix it the screen is damaged.
Punteggio 0
The screen needs to be replaced as long as phone can receive and call out if screen allows. Still accessible with Bluetooth earpiece or automobile. Everything else is working except screen.
Punteggio 0
Aggiungi la tua risposta
Jami Russell sarà eternamente grato.
Visualizza Statistiche:
Ultime 24 Ore: 2
Ultimi 7 Giorni: 19
Ultimi 30 Giorni: 53
Tutti i Tempi: 1,591
