Salta al contenuto principale
Seconda generazione di iPhone. Modello A1241/8 o 16 GB di memoria/plastica posteriore bianca o nera. La riparazione è più semplice rispetto al primo iPhone. Richiede l'uso di cacciaviti e strumenti di leva e distacco con ventose.
1158 Domande Visualizza tutte
iPhone Camera Shutter problem.
I have a problem with my iphone camera. I can open the app but the shutter does not open. it has a knock-off camera. Its a bit bigger than the original one. i have to scrape the back case to let it fit.
Ive check the connections of the camera to the board. No corrosion or anything..
Also, Im using IOS 4.1, i cannot upgrade it to 4.2.1 my BB is 6.15.. i dont like to use a CFW..
hope you could help me.. thank you...
Questa è una buona domanda?
Punteggio -1
Aggiungi un commento
2 Risposte
Soluzione Prescelta
most times if it only shows the shutter then it is connection or camera not software. either replace (you may even have a 3gs camera instead of 3g hence why it doesn't fit-I'm not 100% but I don't think you can swap them) or redo connections again.
Punteggio 4
2 Commenti:
its shape is like a box compared to the original camera.. if its connection the app shouldnt be opening..
im a newbie here..
thanks for the reply..
da
app opens and shows shutter whether camera is installed or not, so that isn't a good guide for whether it's software or not. I think you have wrong/faulty camera. Buy another 3G camera and try that..I think the tell tale here is that what you bought didn't fit!
da
thank you sir...
Punteggio 0
Aggiungi la tua risposta
markeeinsik sarà eternamente grato.
Visualizza Statistiche:
Ultime 24 Ore: 2
Ultimi 7 Giorni: 2
Ultimi 30 Giorni: 2
Tutti i Tempi: 2,859
