Salta al contenuto principale
The iOpener is an insulated, heat-retaining bag that can be heated in a microwave and used to transfer heat to the adhesive along the edge of an iPad or similar device.
23 Domande Visualizza tutte
Is this a good alternative to an iOpener?
The kit I just ordered to change the battery to my XS Max doesn’t come with an iOpener. I can’t find it on Amazon by itself but there’s one on here by itself that I may buy. I was just wondering if I heated up a wet paper towel in the microwave, placed the warm paper towel in a zip lock bag and sealed it would that be a good alternative to an iOpener? (Or even just a warm regular towel inside a zip lock bag)
Questa è una buona domanda?
Punteggio 0
Aggiungi un commento
2 Risposte
Soluzione Prescelta
Frankly I would just use a hair dryer or heat gun (variable temp).
A wet paper towel is risky! The water could sneak in! The other factor is it doesn’t have enough heat mass.
Punteggio 4
2 Commenti:
My hair dryer does an amazing job at high! It burns me.
da
Sounds like you need a cooler hair drier ;-}
da
For difficult things to heat up safely, I wrap therm in a clean cup towel, turn my toaster oven on to bake and sit them on top for a couple of hours.
Punteggio 2
Aggiungi la tua risposta
TMay sarà eternamente grato.
Visualizza Statistiche:
Ultime 24 Ore: 0
Ultimi 7 Giorni: 7
Ultimi 30 Giorni: 37
Tutti i Tempi: 826
