Can I replace a bad logic board with a board from another model?
I want to replace the bad logic board on this machine. Can I use a board from an older or newer MacBook? My current MacBook is the Core 2 Duo one with a 2.16 GHz processor.
Questa è una buona domanda?
10 Commenti
Thanks for the answer. I was given this machine and took it to the apple store and was told the motherboard was bad. It appeared to the tech that there could have been liquid spilled on it, though he was not sure. The unit will not turn on at all.
Gerald
da Gerald
Do you know how the bad motherboard was determined? What did you see them do? How busy were they?
da mayer
The MacBook is 13" 2.16ghz. No I did not see them test it. The tech took it to the backroom for about 15 - 20 minuets and came back with the results.
da Gerald
I clicked the link to the replacement board in your answer & mine does not have the energy star label. Also the picture is different.The manufacturing date on mine at the ram slot is 2006, the board on the link is 2007.
Thanks agian
da Gerald
I'll vote one up on this question cause if I was in the same position than Gerald I would try to find the fastest mobo compatible with my machine since he has to replace it. I'm not a MacBook specialist so I can't try an answer on this but I'm sure Ben Eisenman will have one for Gerald.
da lemerise
Mostra altri 5 commenti
