Salta al contenuto principale
Il telefono allora al top della gamma Samsung, il Galaxy S8, è stato lanciato nell'aprile 2017.
304 Domande Visualizza tutte
Why is my phone getting very hot?
Hi guys, I recently bought this Samsung S8 from someone who claimed it needed a new battery as it was dead. I could tell they weren't the tech savvy type so they obviously weren't trying to rip me off. I put the new battery in and it works great. I start going through factory reset setup and it gets very hot on the right hand side by the lock button. The iris scanner, finger print scanner and camera also do not work and refuse to open for some reason. This phone to my knowledge was never opened and appeared that way when I removed the back cover.
The main board looks perfect, no signs of water damage, the LDI sticker isn't activated so it's definitely not water damaged. It's just getting too hot to handle. I checked CPU temps and they reach 50 degrees just at idle. Usage is normal however on CPU and memory.
I have restarted the phone, cleared cache memory from camera app, wiped boot cache I believe when booted into recovery mode.
Any ideas would be great as I was really excited to upgrade :/
Thanks!
Questa è una buona domanda?
Punteggio 0
Aggiungi un commento
1 Risposta
Make sure the circuit board is seated and screws are tightened correctly.
below the circuit board are cooling pads if your main board is not seated in the phone correctly this can cause overheating.
Also your cameras are not operating check to make sure they are plugged in correctly this could be causing short circuit and potentially overheating
Punteggio 0
Aggiungi la tua risposta
Brandon Frost sarà eternamente grato.
Visualizza Statistiche:
Ultime 24 Ore: 1
Ultimi 7 Giorni: 9
Ultimi 30 Giorni: 18
Tutti i Tempi: 161
