Salta al contenuto principale
Modello fine 2011, A1278 / processore i5 2,4 GHz o i7 2,8 GHz
591 Domande Visualizza tutte
Battery won’t charge/now won’t turn on
Hi,
I have a MacBook Pro late 2011 edition. I was working on my computer when it randomly shut off and when I turned it back on it had an X in the battery icon and the charger light wasn’t turning on. It had been charging all night. I was able to use my computer and tried trouble shooting with turning it off/on and then tried control/option/shift/power all at the same time and it wouldn’t resolve. Now the battery has died and won’t turn on. I have made an appointment to have it looked at. But in the meantime is there anything else I can try? Or will it be able to be fixed or the battery fixed if it won’t turn on? Will I be able to recover my files?
Any help is appreciated because EVERYTHING is on this laptop and I made a rookie mistake and haven’t backed it up. Please help:///
Questa è una buona domanda?
Punteggio 0
Aggiungi un commento
1 Risposta
Your files should be safe since your computer’s hard drive doesn’t need a constant power source to maintain them. Everything should be up and running again once the battery is replaced and the technician runs a diagnostic on your system.
Punteggio 0
Aggiungi la tua risposta
Lauren sarà eternamente grato.
Visualizza Statistiche:
Ultime 24 Ore: 2
Ultimi 7 Giorni: 2
Ultimi 30 Giorni: 2
Tutti i Tempi: 37
