Salta al contenuto principale
Released in June 2017 as a successor to the Surface Pro 4. Also known as Microsoft Surface Pro 12.3". Model number: FJT-00001.
51 Domande Visualizza tutte
What adhesive tape to use for Surface Pro 5?
I am replacing the battery on a Surface Pro 5 and re-using the screen assembly.
Does anyone know what type of adhesive tape would be best for re-assembly.
I want to find out what is close to the factory tape in thickness, adhesion, and type as possible. Any recommendations would be greatly appreciated!
Questa è una buona domanda?
Punteggio 0
Aggiungi un commento
1 Risposta
Risposta Più Utile
I’ve always used Tesa tape brand (link below) with excellent results. Its the right thickness and holds very well.
I mostly use 2 and 4 mm.
Tesa 61395 Tape
Immagine Tesa 61395 Tape
Prodotto
Tesa 61395 Tape
$5.99
Punteggio 1
2 Commenti:
Perfect, this is what I have on hand from a previous Surface Pro 4 repair.
Did they change the tape to a thicker foam type tape for the Surface Pro 5?
I thought I read somewhere that it's different the previous models.
da
That I do not know. I've just had great look with Tessa tape on all repairs that either dont come with precut adhesive or need a little bit more applied.
da
Aggiungi la tua risposta
William Blalock sarà eternamente grato.
Visualizza Statistiche:
Ultime 24 Ore: 1
Ultimi 7 Giorni: 2
Ultimi 30 Giorni: 12
Tutti i Tempi: 776
