Salta al contenuto principale
Model A1174 with 2 GHz Core Duo or Model A1207 with 2.16 or 2.33 GHz Core 2 Duo
Cannibalize internal optical drive to use as an external optical drive
I have a 20” EMC 2118 iMac that will be parted and/or recycled. I was wondering, since modern day iMacs and Macbooks do not have optical drives, if there is a kit I could purchase to convert the EMC 2118 optical drive to an external optical drive should I need one. Thank you in advance for your help.
Questa è una buona domanda?
Punteggio 0
Aggiungi un commento
1 Risposta
Soluzione Prescelta
Sadly, you have a few issues that don’t make this very practical.
This older optical drive has a PATA interface you’ll need an adaptor to convert to SATA or in a case which offers a PATA (or SATA) to USB support logic, these older cases are hard to come-by.
The next issue is the needed drivers have long since been dropped in the newer OS releases.
Punteggio 1
Aggiungi la tua risposta
Theresa Albert sarà eternamente grato.
Visualizza Statistiche:
Ultime 24 Ore: 0
Ultimi 7 Giorni: 0
Ultimi 30 Giorni: 0
Tutti i Tempi: 149
